Welcome!
By registering with us, you'll be able to discuss, share and private message with other members of our community.
SignUp Now!
How to build website like racevpn.com
Zimdx Gsm
The Uploader ✅
Staff member
Joined
Aug 2, 2025
Messages
520
To build a website like RaceVPN.com, which offers VPN services (free and paid), you need to combine several components: VPN server infrastructure, user management, subscription system, and a front-end website.
Here’s a full step-by-step guide to building your own site like RaceVPN.com:
✅ PART 1: PLAN FEATURES YOU WANT​
Features to replicate from RaceVPN.com:​
  1. ✅ Multiple VPN locations (Free and Premium)
  2. ✅ Daily free VPN account generation
  3. ✅ Premium account purchase and management
  4. ✅ Server status display
  5. ✅ User dashboard to manage VPN access
  6. ✅ Clean, mobile-friendly front-end
  7. ✅ Automated account creation and expiration
✅ PART 2: INFRASTRUCTURE SETUP (VPN Servers)​
🔧 Tools You'll Need:​
  • VPS servers (Contabo, Hetzner, DigitalOcean, etc.)
  • VPN software: OpenVPN, WireGuard, or SoftEther
  • Control panel (optional): Streisand, PiVPN, or custom scripts
📦 Set Up a VPN Server (OpenVPN example):​
On each VPS (Ubuntu 20.04+):
Bash:
wget https://git.io/vpn -O openvpn-install.sh
chmod +x openvpn-install.sh
./openvpn-install.sh
You'll be prompted to:
  • Set up a client name
  • Enable client DNS
  • Generate .ovpn file (store it for delivery)
✅ Repeat this for each server location.
✅ PART 3: BACKEND DEVELOPMENT​
You can use:
  • PHP + MySQL (RaceVPN uses this stack)
  • Or modern stack: Node.js, Python (Flask/Django), Laravel, etc.
Backend Features:​
  • User auth (register/login/reset)
  • Free VPN account generator (daily limit per IP)
  • Admin panel (add/remove servers, check logs)
  • Premium account system (Stripe, PayPal integration)
  • Expiry date tracking
  • Server status monitor (ping check)
Database Schema Sample:​
Bash:
users (
  id INT PRIMARY KEY,
  email VARCHAR,
  password_hash VARCHAR,
  role ENUM('user', 'admin'),
  created_at DATETIME
vpn_accounts (
  id INT PRIMARY KEY,
  user_id INT,
  server_id INT,
  type ENUM('free', 'premium'),
  created_at DATETIME,
  expires_at DATETIME,
  ovpn_file TEXT
servers (
  id INT PRIMARY KEY,
  country VARCHAR,
  ip_address VARCHAR,
  active BOOLEAN,
  max_users INT,
  current_users INT
✅ PART 4: FRONTEND DEVELOPMENT​
Stack:​
  • HTML/CSS + Bootstrap or Tailwind CSS
  • JS (Vanilla or jQuery)
  • Responsive layout (mobile-first)
Pages to Build:​
  • Home page (like RaceVPN with server cards)
  • Free VPN generator
  • Premium plans page
  • Dashboard (login required)
  • FAQ / Contact
You can scrape some visual inspiration from RaceVPN’s HTML, but don’t copy code directly.
✅ PART 5: AUTOMATE VPN ACCOUNT CREATION​
Option A: Script-based (easiest)​
Use backend scripts to SSH into the VPN servers and run account generation.
Example (for OpenVPN):
PHP:
<?php
$server_ip = "your_server_ip";
$ssh_user = "root";
$client_name = "user_" . time();
$command = "echo '$client_name' | ./openvpn-install.sh --add-client";
$connection = ssh2_connect($server_ip, 22);
ssh2_auth_password($connection, $ssh_user, 'your_password');
$stream = ssh2_exec($connection, $command);
stream_set_blocking($stream, true);
$output = stream_get_contents($stream);
// Save output to database or serve .ovpn to user
✅ PART 6: USER PANEL / DASHBOARD​
Should show:
  • User info
  • Account status
  • Expiry countdown
  • Button to regenerate config (if free, daily)
  • Option to upgrade to premium
✅ PART 7: PAYMENT INTEGRATION​
Use:
  • Stripe (for credit/debit)
  • PayPal
  • Cryptocurrency (CoinPayments.net or NowPayments)
After successful payment:
  • Update database
  • Automatically generate and deliver premium config
✅ PART 8: ADMIN PANEL​
Admin should be able to:
  • Add/remove servers
  • View users and logs
  • View server load
  • Ban IPs (if abuse)
  • Update scripts and expiration logic
✅ PART 9: DOMAIN + HOSTING​
  • Frontend/backend: Host on shared hosting or a VPS (like Contabo)
  • VPN servers: Spread across multiple VPS providers worldwide
  • Use Cloudflare for DDoS protection, SSL, CDN
✅ PART 10: OPTIONAL ENHANCEMENTS​
  • 🌐 Multi-language support
  • 📱 Mobile app (use WebView or native app)
  • 📊 Server status auto-refresh (AJAX)
  • 📁 Download page with multiple client formats (.ovpn, WireGuard .conf)
🧰 FULL TECH STACK SUGGESTION (LIKE RaceVPN)​
LayerTool/Tech
FrontendHTML/CSS + Bootstrap
BackendPHP (Laravel or raw PHP)
DBMySQL
VPN ProtocolOpenVPN / WireGuard
AutomationShell Scripts + SSH from PHP
PaymentsPayPal / Stripe / CoinPayments
HostingVPS (Contabo, Hetzner, etc.)
💡 Want a Ready-Made Starter Template?​
I can generate a starter Laravel or PHP + HTML template with:
  • Login/Register system
  • Free VPN generator logic
  • Admin dashboard
  • Bootstrap front-end with location cards
Let me know if you'd like the code or ZIP version to start with.
Back
Top
